Change of ORIGIN problem
StuartBruff
23-Emerald II
I have a problem with ORIGIN in Mathcad Express 7.  I use the default ORIGIN at the start of a worksheet, do some calculations, then change to ORIGIN = 1, do some calculations, then change back to ORIGIN = 0 and repeat the original calculations.   However, whilst Mathcad reports that ORIGIN has changed to 1, it seems to behave as though the ORIGIN is still 1.   I don't know what I'm doing, or thinking, wrong.
The attached Mathcad Express 7 worksheet may, or may not, show the problem.
Stuart
StuartBruff
23-Emerald II
(To:o.svahn)
Thanks for the reply.   Whilst looking to see what you were referring to, I found the problem.  When I set ORIGIN:=0 (in the 2nd blue highlighted region), for some reason it set the Label to "Variable".
Changing the Label to "System" produced the desired result.
Cheers,
Stuart
4 REPLIES 4
Hi there
you need to set ORIGIN:=0 resp ORIGIN:=1 - not ORIGIN=0
regards
Owe
StuartBruff
23-Emerald II
(To:o.svahn)
Cheers,
Stuart
LucMeekes
(To:StuartBruff)
Welcome to the magical world of Autolabelling in Prime...
StuartBruff
23-Emerald II
(To:LucMeekes)
It was having a vague recollection of you mentioning it in a recent post that made me check.
I've got used to the fact that Prime doesn't regard different fonts as being different Labels, unlike M15.  For various nefarious reasons, I change specific regions' Math Fonts to suit my needs, so the difference in font style between System and Variable didn't pop out as something that needed investigating.
Cheers,
Stuart
