EQUATION SOLVING
ptc-2315322
1-Newbie
EQUATION SOLVING
I am new to mathcad,
i can't able to solve algebra equation.
in the attached file, i want to find ZM by trial and error until the value of the equation: A-B+C*D becomes 0.
Please Help
6 REPLIES 6
(To:ptc-2315322)
ZM, D?
Could it be that you attached the wrong file?
Mathcad has solved your problem. The answer is X=1, Y=1, and Z=1.
I've added an illustration of matrix times vector so you can check.
Previously i attached wrong file
please find the correct file attached
See please the attach
B has to made dependend on ZM, too.
So you get ZM=59.689.
OK!
No solution but a way to solution!
