Insert RTF, HTM, or PDF Pages
ELSID
I have a report I need to import into MathCAD. The program says that it will generate an HTML or RTF file. Which would be better to import into MathCAD v14 M030?
EDIT: I try to copy the entire RTF file and it only pastes one page at a time. This is being brought in as a word file. If I say, import RTF, all formatting is gone and a whole bunch of garbled "data" is introduced (Garbled data=letters and symbols) as well as loosing the formatting. Any suggestions?
6 REPLIES 6
Fred_Kohlhepp
23-Emerald I
(To:ELSID)
Unfortunately, importing into Mathcad is one of the failings of the program. I have pasted parts of PDF files into Mathcad sheets; after only a few things get very slow--copying an equation may take several minutes, I've never discovered why. Pasting in large quantities of text tends to have the same effect.
I'm driven to ask why you need to import so much into Mathcad; it's not like the program will use any of it in computation. . .
Fred Kohlhepp
fkohlhepp@sikorsky.com
ELSID
(To:Fred_Kohlhepp)
Calculation formatting. Have same headers and footers. It goes to the long standing request request of adding MSWord features into MathCAD.
An analysis from one software is being used as input into a MathCAD sheet
Let the word document saved as 2003 doc format in a separate file. Adjust left and right margins at what you want to see in mathcad. Then paste special, as referenced object. If you don't want to mix text and math (insterting math into text regions in mathcad) I see that this is a very well tool to write reports.
Notice that if you write into word, changing the size and location of referenced texts, mathcad can update them correctly - that's not the case with ms excel.
Also try to experiment saving ms word as doc, but with the html viewing: then you can resizing the fragments to different withs too.
There are a small issue that sometimes word go to some standard page with, and other related with the fact that even it is better paste entire paragraph, you must to leads with an extra carriage return in the image into mathcad.
Regards. Alvaro.
ELSID
(To:AlvaroDíaz)
Alvaro,
Got lost in translation. Please explain in Spanish if that is your native tongue.
Es como redactar el manual de un control remoto de televisi�n: nadie va a querer leerlo luego. Los procedimientos son simples, pero si se los v�; leerlos puede resultar entre tedioso y molesto. A pesar de eso aqu� va el intento, s�lo que esta vez en verdana materna.
Hay varias formas de copiar y pegar, pero fundamentalmente son dos: como texto (ya sea con o sin formato) o como objeto.
En lugar de pegar como texto he encontrado particularmente �til el hacerlo como objeto.
A su vez, habr�a dos tipos de formas de mostrar un objeto dentro de otro: vinculado o incrustado (palabra por cierto m�s inofensiva que la que suele usarse en el habla inglesa).
La pr�ctica de incrustar desde word no ofrece mayores riesgos, sin embargo desde excel (y creo que s�lo desde �l) hace que todo el libro de trabajo se copie �ntegro. Lo cual suele generar r�pidamente archivos muy grandes.
Es decir, como praxis gen�rica pudiera tomarse el vincular objetos, y no el incrustarlo.
Como beneficio adicional se tendr�a que en Word -y no as� en Excel- el modificar el tama�o de los p�rrafos no altera el resultado, pues Word actualiza correctamente en Mathcad la im�gen vinculada. Esto no sucede con Excel, donde por ejemplo el insertar filas no desplaza hacia abajo la im�gen luego de actualizarla.
Para poder vincular objetos hay que recordar que se necesitan dos archivos, uno fuente y otro destino. El archivo fuente, para el caso de word, adem�s, si est� guardado con la vista en formato html tendr�a la ventaja de que puede redimensionarse sin necesidad de cambiar los m�rgenes del documento.
Como yo no suelo mezclar texto y matem�ticas en mathcad encuentro muy �til esto, aunque claro tiene varios inconvenientes. Primero, aparentemente habr�a que copiar en word p�rrafos enteros, lo cual agrega a veces un rengl�n extra. Segundo, la numeraci�n autom�tica porfiadamente se reinicia sin motivo aparente por lo cual m�s bien parece un buen bug en word m�s que un efecto intencionado, el cual se ha mantenido a lo largo de las versiones y actualizaciones de word.
Finalmente, si word puede actualizar p�rrafos, �porqu� mathcad no? Es decir, si tengo un informe elaborado en mathcad, lo l�gico ser�a que para hacer una presentaci�n de �l utilice power point por ejemplo. Si mi informe no es definitivo -como sucede habitualmente- ser�a mejor pegar mathcad en power point como objeto vinculado. Adem�s, mathcad tambi�n se incrusta entero dentro del programa destino, por lo cual incrustar no pareciera buena praxis. Sin embargo el agregar espacios en mathcad hace que todos los v�nculos queden desplazadas en power point.
Al respecto hice una sugesti�n, sobre cuyo destino final preferir�a no elucubrar demasiado:
http://collab.mathsoft.com/read?110169,12
Saludos. Alvaro.
ELSID
(To:AlvaroDíaz)
Muy amable. Escrito mucho m�s claro y definida. He estado jugando con ambas formas, y pens� que otra alternativa ser�a PDF. Esperemos que PTC agrege algunas caracter�sticas de "WORD" en la pr�xima versi�n.
Saludos.
