Global Fits (parameter linked)
Jbryant61
Hi, I have attempted a simple equation to several sets of data. I am having trouble constraining one of the parameters to be linked for all data sets.
Is it possible to plot a variable number of data sets on a graph, depending on the number of columns in the data table?
Any assistance greatly appreciated.
Jason
10 REPLIES 10
RichardJ
(To:Jbryant61)
You have to fit all the data sets at the same time.
Richard
Jbryant61
(To:RichardJ)
superb..Thanks Richard.
Jason
Jbryant61
(To:RichardJ)
Richard, I think your global "y-axis" part is using values for the fit from the SSE results from my part. After deleting all the SSE part as you suggested, your graph no-longer works!
J
Jbryant61
(To:Jbryant61)
Sorry, I know why now, as you said, I need to build the residual for all 4 y columns!!
Jbryant61
(To:Jbryant61)
sorry one more thing. I am requested to express the Rsquared value. Instead of minising the residuals, could I equally well minimise the residual squared, and then use this for the denominator for the Rsquared. I have read that the numerator shoudl be the sum of the y values squared for my data, is this correct?
Jason
RichardJ
(To:Jbryant61)
>residual squared,
Not if you want it to be a least squares fit.
Minimize the residuals, and then just calculate the Rsquared separately.
Richard
RichardJ
(To:Jbryant61)
>Rsquared value.
Be aware that for Rsquared to have any statistical meaning the errors (i.e. the residuals) must be random and normally distributed. Yours clearly aren't, because the equations does not fit the data very well.
Richard
Jbryant61
(To:RichardJ)
Hi Richard, I had messed the "a" relation, it should all be related to the last column. The fits are a lot better. Im struggling with the R squared!
Jason
RichardJ
(To:Jbryant61)
On 2/24/2010 11:47:13 AM, Jbryant61 wrote:
> Im
It's a simple calculation
Richard
Jbryant61
(To:RichardJ)
Thanks.
