Security Alert Log4j Security Vulnerability. Click here to know more.
LU Decomposition
Teddy
LU Decomposition
Anyone can help me reverse this program?
This program contains the lower left side triangle to be 0, and I want the program to run on the opposite side on the upper right to be 0.
My program does not seem to be working properly. If anyone can help me reverse "0" in the matrix, that would be a great help in my studies.
Thank you.
15 REPLIES 15
LucMeekes
23-Emerald I
(To:Teddy)
Instead of (or next to) a picture, you should post your worksheet, or at least a worksheet that contains your specific problem. That will greatly help us help you.
Have you considered using the LU() function that is built into Prime?
Teddy
(To:LucMeekes)
I have been attaching my Prime file on the message for more than 1 hour, but it keeps on failing to attache the .mctx content type and keeps on getting removed.
No, I haven't tried the LU() function on the Prime. I wanted to play with the basics for now before using the shortcut LU() function.
LucMeekes
23-Emerald I
(To:Teddy)
You should not attach an .MCTX  (template) file, but the .MCDX (worksheet) file...
And in case all else fails, you can zip the file and attach that archive.
Teddy
(To:LucMeekes)
It still says it doesn't match its file extension and has been removed. I already tried zipping it, the mcdx and the mctx, and it still fails.
Hi
Prime LU decomposition on your matrix in the file.  Usually the matrix should be square?
Cheers
Terry
Teddy
(To:terryhendicott)
I dont think it should be squared all the time. The last column is considered to be the constant. Was looking for a opposite side of my program, just to have the 3 "0" to be on the upper right side of the matrix.
I can do it manually, but I want to learn how to do the process by using the program of Mathcad Prime itself.
HI,
Found on the web the algorithm in C++ to calculate LU Decomposition of square matrices.
Converted side by side the C++ coding to Prime programming.
f_LU function gives the same answer as the web page example results.
It does not get the same answer as MathCad Prime LU function?.
It depends which L or U diagonal is normalized
Cheers
Terry
Hi
Only two changes to the algorithm to get it to work on Rectangular matrices.
Cheers
Terry
Teddy
(To:terryhendicott)
The mathcad that I am using is 6.0. Is there any chance you could lower the version so I can see the continuation of the program?
Thank you.
Some members of the community know how to save back from 7 to 6.  Trust they see this and can backdate it.
If you don't mind coding yourself here is the total program as screen shot.
Cheers
Terry
Have simplified the coding slightly that saves a few lines.  Work in progress.
Cheers
Terry
Teddy
(To:terryhendicott)
Thank you for the great program. I'll try to analyze it and try to understand the program better. I'm still struggling with programming using mathcad Prime. I really appreciated the help.
Your welcome.
Cheers
Terry
(To:Teddy)
Here is Terry's worksheet converted back to version Prime 6 - hope it works OK for you
Thanks Werner,
Teddy will be able to see the C++ code next to the Prime programming.
Cheers
Terry
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
