Mathcad 15.0 format painter for plots
mkarbassian
1-Newbie
Is there a way to copy the plot properties from one plot to another like the format painter function in MSWord?
I have a ton of plots on numerous sheets, each with multiple traces that need to have certain color scheme, trace thickness, etc. duplicated on all of them.
This is too cumbersome. Hopefully this can become a standard function in Mathcad (15 or Prime).
Another cool feature would be a direct link provided on the help menu for "feature search/request" that would let the user browse through the existing feature requests and add a new one if was not already there.
Thanks.
10 REPLIES 10
I copy the plot and edit it!
Wish you had read my question one more time before answering. The idea is to avoid exactly what you're suggesting.
LucMeekes
(To:mkarbassian)
There is no format painter. The work-around is as suggested by Valery.
I think your feature request for browsing and adding feature requests will probably be put on the pile of existing feature requests and still lacking features for Prime w.r.t. Mathcad (Hardly/no new features are added to Mathcad 15) and will find its way to implementation as swiftly as the rest of that pile.
It's like putting the stack pointer on the stack...and only there.
You're the one here that knows what he's talking about. Thanks for your realism.
Valery is right. Copying a plot in Mathcad 15 copies all formatting and settings. Just delete the x & y axis parameter lists and add (or cut-and-paste) your own.
Tip: To copy a plot from Mathcad 15 to MS Word, paste it in MS PowerPoint as a windows metafile then copy that to Word as an enhanced metafile.
Ralph
Thanks for the basic instruction but please note that the power user is trying to avoid exactly what you are suggesting to save precious time on a large project.
RichardJ
(To:mkarbassian)
In Mathcad 15, create a blank plot with all the line settings, etc, that you want. Save that as a Mathcad XML template (if you overwrite Normal.xmct it will be the default for a new worksheet). All the settings are saved with the template, including the plot size, and a new plot will default to those settings. The plot can even be deleted from the template, but I'm not sure if you have to save it once first with the plot to get the plot settings to stick.
I don't think this works in Prime.
Thanks for the instructions but that's for "new" plots only. I'm asking about existing ones that need to be formatted uniformly and quickly.
Unlike EXCEL, there is no "paste special/formats"
Thanks Fred. I am aware of that. That's why this is basically a feature request. The support team just wanted to close my ticket asap regardless of it getting anywhere.
