Matlab short-circuiting behavior into Mathcad
JB_9681141
Hi, i need this operator in mathcad (ll)
ll  Represents a logical OR operation that employs short-circuiting behavior. That is, expr2 is not evaluated if expr1 is logical 1 (true). Each expression must evaluate to a scalar logical result.
cf2e3bba-1001-4d5f-bd6a-d0290a1f14f3.jfif
7 REPLIES 7
Look at the Boolean toolbar.  The v symbol does what you want.
Alan
LucMeekes
(To:AlanStevens)
It does the OR, but it doesn't 'short-circuit', does it?
Mathcads OR does short circuit eval, otherwise doIt(0) would throw an error in the following example
LucMeekes
(To:Werner_E)
Ah, (real) Mathcad does,
but Prime:
I've been using Prime too much...
LucMeekes
(To:JB_9681141)
I have found no reliable way to do that in Mathcad.
Do you really need it to short-circuit?
If your first expression is 'per',  then the second expression 'per<0' can also be calculated...
Mathcad (or at least as I use it) doesn't have functions that return logical true/false.  How about
playing games:
