Matrix Equation
Highlighted
Garnet
Matrix Equation
Dear All
Could you help me please ? How to write this equation in Mathcad Prime ?
17 REPLIES 17
Highlighted
Re: Matrix Equation
what you are looking for. I see a table. Do you need a formula to calculate output as per the table based on input? Then you need to be specific what the inputs are.
Highlighted
Re: Matrix Equation
Thank you for reply , Mr./Ms. LucMeekes,
i want to write equation have condition like that.
following table as previous, thank you so much.
Highlighted
Re: Matrix Equation
This still leaves much to guess!
I propse YOU start entering the information on a mathcad sheet, and make an attempt to write up the equations. If you run into problems, attach the worksheet (NOT just a picture) and provide a clear problem description.
Then we may be able to help.
Highlighted
Re: Matrix Equation
Help me please.
Highlighted
Re: Matrix Equation
Missing:
- Worksheet
Highlighted
Re: Matrix Equation
I’m have not excel and mathcad prime worksheets. So, please help me.
Best regards
*Yorn Engtang*
*UR**A**TA S.E**(CAMBODIA)Co.,Ltd.*
[BTP BRANCH] : ANINA Building 4F, No. 240, Street
271, Boeung Tumpun, Meanchey, Phnom Penh,
Cambodia.
[Head Office] : The iCON Professional Building VIP #1-E6
Norodom Blvd, Tonle Bassac, Chamkarmorn,
Phnom Penh, Cambodia.
Tel 😘 023 900 250/ 015 571 616/ 095 **571 616*
Email :
*yorn.engtang@uratase.com <>
: yornengtang609@gmail.com <>*
Highlighted
Re: Matrix Equation
Are you using Mathcad 15 or Prime as there is a subtle difference when it comes to "if" statements.
Look up "if" in the help system and have a go like Luc suggests.
Cheers Terry.
Highlighted
Re: Matrix Equation
Hi
I want to write it in Mathcad Prime.
If you don’t mind, could you help me with that please?
I would appreciate you.
Highlighted
Re: Matrix Equation
Then I need a Mathcad Prime worksheet...
(NOTE I do NOT to know where you work etc. )
So start up your Mathcad Prime and enter the information regarding the equations as far as you can.
When done, save the worksheet and attach that ( .MCDX file) to your message.
Highlighted
Re: Matrix Equation
You can vectorize Boolean comparisons
Prime 4 attached
Highlighted
Re: Matrix Equation
 Hi Mr. FredKohlhepp
I'm really thank you for your help me. i respect you for your kindly shared me.
Highlighted
Re: Matrix Equation
Above is condition to determine what's type building following the table above.
Please help me please sir. thank you in advance.
Highlighted
Re: Matrix Equation
See if the attachment does what you want.
Highlighted
Hi Mr. FredKohlhepp and all friends, Could you introduce...
 Hi Mr. FredKohlhepp and all friends, Could you introduce me, how to write this equation please?
Highlighted
Re: Hi Mr. FredKohlhepp and all friends, Could you introduce...
First and before all: Always attach the Prime worksheet, NOT just a picture!
1. Tables are a nice feature of Prime but they can NOT be used to display results.  Tables are for input only.
2. Z is a vector, an array of values. You need to index Z in order to address it's individual values.
3. Your first condition uses a regular m, I think you need that to be the unit m.
4. In general you should take care of ALL possible situations. What should Kz be when Z>Zg ?
Here's a possible way:
Highlighted
Hi Mr. LucMeekes, i would like to say  thank so much for your best kindly shared me for this advice.
Highlighted
The Last Value of Matrix.
Hi Mr. LucMeekes & Mr. FredKohlhepp, can you tell me, how to write this equation? please help . thank you for your kindly shared us good knowledge.
