Need help making flow charts. No idea where to start!
amanda
I am new at Mathcad and for loops. I need help making two flow charts please! I do not know what to add and what should not be in the flow chart.
and this one.
Attach please Prime files.
amanda
(To:amanda)
Here is the file . Hopefully it helps.
(To:amanda)
I am not sure what you need. The two routines seem to work and to do what they are supposed to do.
If you really need just flowcharts of the two programs - thats nothing specific to Mathcad and nothing you can do with Mathcad. You may need a grahics program or search the net as there are a lot of programs out there specialized on that subject.
IRstuff
3-Visitor
(To:amanda)
Most likely, you should be using something like Visio, which has a bunch of flow chart templates in its library.
Essentially, your flowchart should reflect almost everything that you have in these programs, i.e., there ought to be a box or loop or some other feature for every line in the program.
TTFN
