Piecewise Function
prajendran
11-Garnet
Piecewise Function
I need help in creating a piecewise function for  the black function so that it starts at  the red point and ends on   on black and i want to create a loop for the black function to do this every 2*pi/N degrees please help.
8 REPLIES 8
Cheers
Terry
Hey I couldn't open.
Could you please send xps of this so I can see the entire file?
Hi
What version of Prime are you using?  I have enclosed a pdf.
The only new stuff  at the bottom of your file is this:
Prime 4 Enclosed
This wasn't what I was asking for.
I was asking for how to make the blue curve stop on black and make a circular pattern/array of the current blue curve.
LucMeekes
(To:prajendran)
The word 'blue' does NOT appear in your original post...
How certain are you about what you are asking for?
Luc.
(To:prajendran)
Here's a brute force approach for what you were asking for.
Not sure if it makes any sense, though.
Worksheet in format P4 attached
ttokoro
20-Turquoise
(To:prajendran)
2D and 3D stars
