Prime 3.1: Method for converting range variable to vector no longer works!
StuartBruff
In Mathcad 15, if I want to convert a non-integer range variable to a vector, I can use several techniques, including this:
However, in Prime 3.1 all I get is this:
I want to complain!
Stuart
8 REPLIES 8
(To:StuartBruff)
I want to complain!
Responsive as PTC usually is, you sure will get feedback and a solution very soon.
Let them please a little bit of time, because they just have to first implement MDAs and a few other odds and ends.
Seems like the internal loops are now implemented differently.
Some other of the old and dirty tricks still work, like the assignment with in-line evaluation:
Werner
StuartBruff
(To:Werner_E)
Werner Exinger wrote:
I want to complain!
Werner
I'm not normally paranoid, but I'm beginning to think they do these things just to annoy me.
Stuart
RichardJ
(To:StuartBruff)
You are not paranoid. They do
StuartBruff
(To:RichardJ)
Thank goodness for that! I thought I was going crazy.
RichardJ
(To:StuartBruff)
This at least still works:
You do have to define the range variable though, because it won't let you pass a range value as an argument (why?).
StuartBruff
(To:RichardJ)
As does my vec function ... thankfully,
Tell me about it, already.   I pointed this out years ago ... Re: Convert Nested Array to Matrix
Stuart
LucMeekes
(To:StuartBruff)
So they've implemented the behaviour of good-old Mcad 11:
into Prime 3.1:
StuartBruff
(To:LucMeekes)
into Prime 3.1:
I do hope the loss of recursive local functions in Prime isn't a step towards the "good-old M11 behaviour" of *no* local functions!
Stuart
