I have a problem with PTC Mathcad Prime 3.0
It wont open at all.
It comes with the error: "An Unhandled exception occurred on the dispatcher thread. See C:\Programdata\PTC\Mathcad Prime\Logs\Mathcad Prime_Exception_20151021_135622.log for more information. Prime will attempt to save any modified files and close. Please restart the application."
I have tried to reinstall it and of cause restarted the application. Nothing works. I've looked on the internet, but couldn't find any solution to the problem.
Please help, need the program for Gym.
Have you tried turning off multithreading?
To turn off "Multithreading":
1. Go to "Calculation" tab --> "Calculation Options" button.
2. Click on the "Multithreading" button.
Where do I find this?
Because I can't open Mathcad at all?
Under the calculation tab.
Mike
I can't open mathcad to do that.
Windows OS?
Are you contacted with PTC's technical support? Link for "Mathcad Support Center": Mathcad Support Center
For some reason i can't contact the PTC support.
Just FYI ... in Czech Republic, end customers cannot open Case at PTC. Only VARs can do it.
Maybe you can contact PTC Support via phone.
MH
Morten,
you can uninstall Mathcad Prime 3.0 and install Mathcad Prime 3.1. I am not sure if it helps, but you can do it .
MH
