Rnd in Mathcad
Re: Rnd in Mathcad
Hmm, I loaded your sheet and it seems to calculate pretty well to the values from the book you mention. I had to cancel operations as the last few expression seemed to calculate "endless".
Prime files are so slow and cumbersome to navigate and edit and even cancelling calculation is so much more difficult. In Mathcad i would just press ESC and eventually Mathcad would ask me if I want to cancel.
In Prime a first have to switch to the appropriate ribbon and then press the button - not so easy if mouse and keyboard are hardly reacting to anything because Prime uses up most ressources. Again I confirmed why i don't like that crap.
Re: Rnd in Mathcad
Do you only now break Prime
Smetime we must press Ctrl+Alt+Del
Re: Rnd in Mathcad
No, I had to cancel operations quite often in Prime and it was a hassle most of the time
Yes, sometimes I wasn't able to go to the calc ribbon and also had to kill the task via taskmanager.
I am not saying that mathcad 15 is perfect with all those processes being left in memory ever so often, but Prime definitely is worse.
And no, I won't buy new hardware just to be able to run new program with half the speed and half the features.
"half the features"? Sorry, that was unfair against Mathcad 15.
Re: Rnd in Mathcad
What's wrong with this assessment of the rnd function:rnd.png
The results come pretty close to what they should be.
Re: Rnd in Mathcad
Thanks, Luc!
I think too that in Mathcad not all is Ok with rnd
