Setting default units in Mathcad Prime 3.0
Hello Everyone,
my problem seems to be trivial, but I couldn't find a solution yet:
I would like to set the default units for the results of equations, because the default SI-Units are useless and hardly readable in my case.
I am using mostly kN as force, cm^2 as area and kN/cm^2 as tension (pressure).
How can I set these Units as default units for the results of expressions? I don't like to change the units m^2 to cm^2, N to kN and so on everytime as a write an expresion. I would like To have this done by Mathcad.
Kind regards,
Helmut
Sorry, may be we do not need in Prime MKS and None - but Custon position we need!
