Solve Block Problem
oşentürk
Solve Block Problem
Hello;
I have 5 equations 5 unknowns in the solve block which all of them are functions of a range variable. Solve block always gives error, what is wrong?
Please see the attached mathcad file below. Thanks for help
I didn't understand what you have done but tried as you show but it doesn't give any result???Ekran Alıntısı.PNG
Send please the sheet!
Thanks for your interest.
It is very difficult to edit not own sheet.
I have showed you not a solution but a direction to solution.
You must solve a normal system but delete one variable in the guess values area and create a function with this argument.
