Symbolic puzzle
ttokoro
20-Turquoise
Symbolic puzzle
From the WWW pages.
Find all answers!
1 ACCEPTED SOLUTION
mpomerleau
6-Contributor
(To:LucMeekes)
LUc,
one mistake -
Should be "Sun x Moon + Star - 38" in 2nd puzzle
10 REPLIES 10
ttokoro
20-Turquoise
(To:ttokoro)
Find all answers!
ttokoro
20-Turquoise
(To:ttokoro)
Find an answer!
ttokoro
20-Turquoise
(To:ttokoro)
Find the answers!
LucMeekes
(To:ttokoro)
You want ALL answers?
(Assuming the smiley's code for just two variables):
mpomerleau
6-Contributor
(To:LucMeekes)
LUc,
one mistake -
LucMeekes
(To:mpomerleau)
Ah, typo.
OK: show how you solve it.
ttokoro
20-Turquoise
(To:LucMeekes)
After the tutorial of Prime 3.1, my answer is attached.
By the way, I'm not find the answer of Q3 with 6 or 7 unknown marks that Werner_E find the new problem from the same picture!
a+b=13. 5+8  or 4+9
c*d=42.   c, d are 6*7 if the marks are integer numbers from 0 to 9.
e-f=1.     If a+b=5+8 then 4-3 or 3-2 or 2-1 or 1-0.  g is the numbers rest.
              If a+b=4+9 then 3-2 or 2-1 or 1-0. g is the numbers rest.
Or right side of = sign we have already 1, 2, 3 and 4 in equations. In this case no answer.
Tokoro
LucMeekes
(To:ttokoro)
There are more (if not all) roads that lead to Rome...
Thats the problem with hand drawings.
I see three equations with 6 different emoticons and what is asked is the value of seventh.
So 7 or 8 might as well be correct answers as any other number 😉
@ttokoro wrote:
Find an answer!
