Units Error
AlbertSchepers-
Units Error
In writing equations using vectors and units when the form 'a:=f()= xx*units' is used and the results units are changed, when the value of a is used later it is incorrect ie 'b:=a= xx*units'. See the attached example.
I think this is a bug.
This is an old bug that has been fixed. Which version of Mathcad are you running?
Richard
Release 14
build 14.0.0.163
Albert Schepers
You should download and install the service release.
Richard
You can download the 14 m020 from http://www.ptc.com/support/mathcad_downloads.htm/
It is now available to all users.
Mona
