Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
In writing equations using vectors and units when the form 'a:=f()= xx*units' is used and the results units are changed, when the value of a is used later it is incorrect ie 'b:=a= xx*units'. See the attached example.
