I'm getting the variable undefined error for variable "r". Any suggestion?
Three suggestions:
1. Attach your worksheet. It is very hard, to sometimes impossible, to debug pictures. State which version of Prime you are using.
2. Check the labels of the various variables named 'r', to see if they match (= they're actually the same variable)..
3. What is the function supposed to result in when r > Ks and t >to? You need to account for ALL possible outcomes.
No worksheet attached.
To attach a worksheet, use the 'Browse...' button below and to the left of the message edit window.
Sapphire I
Qt is defined for use in other EQ.
Delete the equal sign (evaluation) after the function definition!
It works.
thanks,
