Hi guys,
I've been working with cabling application on ProE and I was able to modify an existing harness very easily.
But, since the new Creo version was released, I'm having a few issues rerouting the bundles and wires.
For example:
- in ProE wf4, I could delete a portion of a bundle and reroute it in a new connector or location.
- now, in Creo, the reroute command is only for changing the path of the bundle/wire by adding new locations between its ends.
My questions are: How can I reroute the bundles in Creo, to a new connector?
and are there any advance training materials for the new Creo Cabling application?
Thank you in advance ![]()
It should be possible to select a bundle, Right Click and select route. From the route dialog you should be able to select a new entry port.
However with that said I do know there is a bug which should be fixed very soon and i would suggest you speak to tech support and register your problem so you can be notified when the bug is fixed.
As a workaround you have extract the wires from the bundle. using multiselect select all the extracted wires, reroute them and then recreate the bundle.
thanks, Jim
