I'm following this tutorial. http://learningexchange.ptc.com/tutorial/2271/importing-and-editing-cloud-point-data-in-creo After I click facet and ok, doesn't appear.
Daniel,
To complete this you need to have Reverse_Engineering license. If you don't have Reverse_Engineering, when you will import file as facet, nothing will appear on graphics.
Daniel,
I see, thank you!
Cool! I didn't know about the offset corrdinate system tool.
I was using Get Data > Import before. This is much nicer. Thank you!
