For a long time now I cannot search *anything* on the support search page.
Is there any reasoning behind it?
Example: I search for "Windchill" and you would expect a result, right?
I always get this screen, no matter how simple or complex the search is:
Steven Spierenburg
You are using an adblocker. Whitelist PTC.com and you will be fine.
Thanks Chris, that worked!
