WOW! Last Friday post for the month of February. Time is flying by. Do NOT miss out on time with the ones closest to you because you are toO busy!
Pipe Specifications
(The series continues…)
For pipe transport at step 6, with a view to reducing costs, you may want to rewatch the movies where Stan Laurel carried a very long wooden beam by himself ...
Always best when your helper knows you well. 😁
Stan Laurel carrying a very long wooden beam - Google Search
Did you miss a word and a letter?
"Time is flying by. Do miss out on time with the ones closest to you because you are to busy!"
^NOT ^o
... and I typically proof read them a couple of times. But when you type what you are thinking & then read it, youR brain supplies the missing words.
(almost had a typo in this post) 🙂
Still had 1!
"then read it, you brain supplies the missing words"
Should be YOUR brain.
But it is Friday, so it is okay if the brain is only partially working today. ☺
Good thing I'm an engineer and not an English major....
(we only work half days on Friday - only half the brain needed...)
Kind of like what happens when a person's brain goes much faster than his mouth and so the words he speaks are in a completely different language from the one in which he thinks ...
It happens to me more than a few times ...
