Hur aktiverar man pipe i Creo 2?
rtaleb
hur aktiverar man pipe funktionen i Creo?
Hi Reza,
You need to be in an assembly in order to access the Piping functionality, via Applications > Piping.
Amit
5 REPLIES 5
Translated via Google:
How to Enable pipe in the Creo 2
how to activate the pipe function in Creo ?
Hi Reza,
Amit
rtaleb
(To:AmitDeshpande)
thanks it works .
you can not use the pipe under prt ?
That is correct, you cannot access the Piping functionality from part mode only assembly mode.
rcook
6-Contributor
(To:rtaleb)
If you are looking for the Pipe feature (used to be in Insert, Advanced, Pipe in WF), it isn't in the ribbon, but you can find it with the command search.
