Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I am trying to create a pattern of features that will rotate as they travel. See the boss in the image below.
I need each group to have the open side of the tower to be oriented in parallel with the green curve. I need a tower at each datum point. I'm using a "point" pattern. I thought I could make the sketch a spline, either within the sketch or by creating a cosmetic curve copy, then make a datum plane that is normal to the curve. Then, when patterned, it would turn at each point. Not so, each plane is normal to the curve segment at the location of the first point. I tried defining the sketch for the open section to be normal to the spline and it does the same.
The group of features patterns fine, it just does not rotate as I need it to. The orientation seems frozen and not updating based on its position on the curve.
Any ideas on how to do this?
[cid:image003.jpg@01D03A3A.2D787E90]
-- This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
I can't fix your problem, but will confirm when working with solid geometry I have struggled with this very thing. Even when being very careful about my selections, it usually has to do with some Pro/E reference assumption that I can never seem to break.
My work around (as you may have already thought of)... Build the boss tower geometry as surface features. Copy the quilt to the rest of your spots referencing a point (for location), and a plane (for orientation). Then trim and solidify the quilts to finish it up.
On Tue, Jan 27, 2015 at 1:03 PM, Doug Schaefer <-> wrote:
> Creo 2, M120 > > > > I am trying to create a pattern of features that will rotate as they > travel. See the boss in the image below. > > > > I need each group to have the open side of the tower to be oriented in > parallel with the green curve. I need a tower at each datum point. I’m > using a “point” pattern. I thought I could make the sketch a spline, either > within the sketch or by creating a cosmetic curve copy, then make a datum > plane that is normal to the curve. Then, when patterned, it would turn at > each point. Not so, each plane is normal to the curve segment at the > location of the first point. I tried defining the sketch for the open > section to be normal to the spline and it does the same. > > > > The group of features patterns fine, it just does not rotate as I need it > to. The orientation seems frozen and not updating based on its position on > the curve. > > > > Any ideas on how to do this? > > > > > > *--* > > *Doug Schaefer* | > > >
I have not tried this myself but it might be worth a try to use a pattern table and add the angle for the plane features?Best RegardsDave************************** David Brainsky * Certified PTC Instructor * Chula Vista, Ca. 91910 * email: - * alt email: - * Cell Phone: 619-253-5137 ******************************
