I'm trying to igure out a way to create this chamfer without doing a sweep. Please see image.
I need a chamfer on the edge, between the two points. I can do stop at reference, but can't seem to select more than one point on which to stop. As you see, I need it between two points.
I can't seem to find the option for stop cases, either.
I'm new to Creo Elements/ Pro E 5.0, but have seven years modeling experience. Thanks in advance for your assistance!
I think my proficiency at Pro/Fanity is 100%.
As I'm new and learning, I ilike to explore other options to see what will get me there. Ultimately, I'll usually pick the easiest one that is accurate. Quite a nifty lil doo-dad there!
