Sweeping an elliptical trajectory
wfalco
On WF4. Yes - WF4.
First time on this forum since the switch over.
I would like to sweep a solid along and ellipse so it looks like a spoon shape (no handle). How can this be done? I've use var traj sweep. Will sweep but results undesirable.
Thanks!
Wayne
15 REPLIES 15
Patriot_1776
(To:wfalco)
Without seeing what you're trying to do, try a regular solid sweep with "Add Inner Faces".  If not, you'll probably need to do a Boundary Blend.
Frank,
See reply to Antonious. Thanks!
Wayne
kschoonover-3
(To:wfalco)
Wayne,
Need a little more info.  You say "sweep a solid", do you mean sweep a cross-section into a solid because Creo/Pro doesn't have a drag solid capability except for creating tessellated envelopes, which won't create smooth geometry.
As for a spoon shape, Var traj sweeps can do a lot, but the best way is to revolve an ellipse into a paraboloid (egg shape) and then cut away a portion.
If this isn't what you want, post a sketch of what you're looking for and I'm sure someone will give it a try.
Cheers,
Kevin
Kevin,
See my reply to Antonious. Thanks!
Wayne
dgschaefer
(To:wfalco)
WAYNE FALCO, I don't see Antonius in this thread.
An option using a boundary blend would be as follows (I don't have WF4 installed anymore, or I'd post a model for you):
  1. Sketch an ellipse
  2. Create a datum plane offset from the ellipse sketch the height that you'd like the "spoon" shape to be.
  3. Create a datum point on that plane at the center of the ellipse.
  4. Create a boundary blend using the sketched ellipse and the point as the two curves.
  5. Create a tangency condition at the datum point to the offset plane.
This should create a nice domed surface which you can use to build your solid.
LinkedIn
My Bad. I have 2 posts. I did not think the first one took. Sorry - new to this format.
Noty sure if this link will take you to other post.
Solved: Re: sweep elliptical sketch - PTC Community
Your solution is basically the idea. Thanks!
dgschaefer
(To:wfalco)
Yep, that's it.  I did see it after posting my response here.
The video he posted is pretty good, aside from the background music.
LinkedIn
Cool. Ha ha. Well - the music was different.
Although Screencast-o-matic said the microphone was off but it recorded anyway.  So I overwrote it with a stock you-tube offering of the right length.
Great job!
Patriot_1776
(To:TomD.inPDX)
'Morning Antonius!  Hey, is that Screen-capture program free?  Thx!
Free with a little spam icon in the lower left.  I downloaded it so access is a little easier...
Screencast-O-Matic - Free online screen recorder for instant screen capture video sharing.
Patriot_1776
(To:TomD.inPDX)
Awesome, thanks bro!
Patriot_1776
(To:wfalco)
So Wayne, what is the final shape?  You should post a pic.
Frank,
Actually - what Antonius did online is my start part. He just tweaked it. That is same result that I have.
Wayne
