mini-toolbar disappeared in Creo5
BJP
11-Garnet
11-Garnet
I was adding a few icons to the mini-toolbar and saved creo_parametric_customization.ui
Now the mini-toolbar does not show up anymore when I left-click anything. The little window only shows up when I right-click (a long time). using a backup of "creo_parametric_customization.ui" does not help.
Is there a way to get the mini-toolbar back?
Im using Creo 5.0.2.0
Tdaugherty
(To:BJP)
Can you check on this setting? You may have to set it to the proper value and export a new customization.ui.
You could also reset your customizations if that doesn't work.
Tdaugherty
(To:BJP)
BJP
11-Garnet
11-Garnet
(To:Tdaugherty)
Thats it, thank you!
