Hi All,
We want to have an indication on the drawing when the drawing is still "work in progress"
or when the drawing is modified.
Therefore we added a note on the drawing connected to a parameter, which is empty
in an release state and not modified.
The parameter is filled with: "For review Only", when it is not released or when it is modified.
So, in this case on the drawing the text: "For Rebiew Only" is visible.
So far, so good.
What we see after releasing the drawing and part is that the note: For Review Only is still visible when it is opened in CREO.
It disappers after regenerating. We verified the status of the parameters but they are ampty as it should be.
It seams that the note on the drawing is not updated on the drawing when it is opened in CREO.
Any suggestion?
Thanks.
regards,
bert
Bert,
I guess that your config.pro file contains the option save_display YES
Martin Hanak
