Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hi Folks, When we changed over to WF4 (M060) we started using IDF 3 rather than IDF 2 which we have used until then. Our ECAD manager is looking to use an aspect of IDF 3 to deal with areas of PCB with zero height restriction. This Other outline functionality is described on page 8 in This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
