Is there a way to turn off the visibility of each reference designator? When you select the note that is attached to the cabling component the show and hide button will not remove the reference designator text off the graphics window. The Note Icon in the model tree on the component greys outs but the text still shows up. I tried to move all the notes to a custom layer to see if I could turn them off individually. That didn't work. It makes it tough to document components with the correct reference designator when you have other note text coming through because there are parts behind the one your trying to show. The only control I see is all On or Off in the entity display option.
