ecad_hint.map Question
ptc-680841
Guys,
I am wondering if there is a way to accomplish this in my hint map file. I want to use one proe model to represent many ecad parts on my board. Sounds simple, but I would prefer only one entry in the "ecad_hint.map" file.
For example, I am looking for something like this, but have no idea if it is possible and what the specific syntax would be. Thought I would ask before trying to test out different possible syntax combinations.
/* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:"; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} p.MsoPlainText, li.MsoPlainText, div.MsoPlainText {margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Courier New"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;}#map_objects_by_name->ECAD_NAME "X01" "X02" "X03"
ECAD_ALT_NAME "ECAD_TYPE "MCAD_NAME "X-ALL"MCAD_TYPE "part"MCAD_LAYER "END#
Without a condensed entry format of some sort, I would have to have three individual entries like this:
ECAD_ALT_NAME "ECAD_TYPE "MCAD_NAME "X-ALL"MCAD_TYPE "part"MCAD_LAYER "END#map_objects_by_name->ECAD_NAME "X02"
ECAD_ALT_NAME "ECAD_TYPE "MCAD_NAME "X-ALL"MCAD_TYPE "part"MCAD_LAYER "END#map_objects_by_name->ECAD_NAME "X03"
Any guidance you can give is appreciated.
Andy B.
Andy,
The hint map file works with wildcards "*"
X0* can replace X01, X02, X03, etc
Keith
On Jun 11, 2010, at 10:07 AM, Andrew Burke <andrew@productview.com>
wrote:
> Guys,
> combinations.
> ECAD_ALT_NAME "
> ECAD_TYPE "
> MCAD_NAME "X-ALL"
> MCAD_TYPE "part"
> MCAD_LAYER "
> END
> ECAD_NAME "X01"
> ECAD_ALT_NAME "
> ECAD_TYPE "
> MCAD_NAME "X-ALL"
> MCAD_TYPE "part"
> MCAD_LAYER "
> END
> ECAD_NAME "X02"
> ECAD_ALT_NAME "
> ECAD_TYPE "
> MCAD_NAME "X-ALL"
> MCAD_TYPE "part"
> MCAD_LAYER "
> END
> ECAD_NAME "X03"
> ECAD_ALT_NAME "
> ECAD_TYPE "
> MCAD_NAME "X-ALL"
> MCAD_TYPE "part"
> MCAD_LAYER "
> END
> Andy B.
> Site Links: View post online View mailing list online Send new
> post via email Unsubscribe from this mailling list Manage your
> subscription
> Use of this email content is governed by the terms of service at:
Thanks Keith! This is working for us and solves the issue for this particular board.
Have a Rant-Free Friday everyone!
Some time back I conducted a few Pro/ECAD webinars to show users how to generate geometrically accurate 3D PCBs in Pro/Engineer. Would there be interest in an encore webinar or two?
Topics covered would be:
-The EMN and EMP IDF Files and how these files can bi-directionally transfer ECAD data to/from Pro/Engineer
-The ecad_hint.map file and how 2D "block" data can be replaced with real 3D PCB Components in Pro/E
-Synchronizing ECAD and Pro/Engineer component geometries
-Best practice design processes for developing 3D PCBs
-How Simplified Solutions Hint Map Tool and 3D Component Library can streamline the process of creating 3D PCBs
-Answer any Pro/ECAD related questions
If you or any of your collegues would be interested, send me a quick reply email . If there are sufficient responses I will set up times/dates to accomodate.
Keith
Keith Richman
Simplified Solutions Inc.
410-420-7853 (United States)
ECAD'ers,
I see it is OOTB functionality to pass certain parameters from ECAD to MCAD using IDF files and the
/* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:"; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} p.MsoPlainText, li.MsoPlainText, div.MsoPlainText {margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Courier New"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;}#map_objects_by_name->ECAD_NAME "XE644"ECAD_ALT_NAME "XE644"ECAD_TYPE "MCAD_NAME "0102042A015"MCAD_TYPE "part"MCAD_LAYER "END#
I also noticed there are many other parameters that I can show in the Model Tree, such as:
ECAD_OWNERECAD_PLACEMENT_STATUSECAD_RESISTANCEECAD_CAPACITANCE
etc.
I counted 19 parameters. I am wondering if it is possible to create a custom parameter and have that passed back and forth? Something like ECAD_DESCRIPTION. What do you think? Am I "onto something" or am I "on something"?
Thanks in advanced for your input.
Andy B.
