Problem with Measure Force
Aquamarine
is it possible to fix this problem?
Thank you
Tags (2)
Re: Problem with Measure Force
FYI ... your picture is not visible.
Martin Hanák
Thank you
I might try putting stiff springs at each of the weighted links - dependent side and use a force measure on the spring.  maybe, but too busy at the moment to look further.
