Click coordinates
TomasCharvat
Click coordinates
Hello friends,
please how is possible to access coordinate values pageX and pageY (position of a click) which are shown in Console log?
Thanks for the answers.
Tomas
mn1
(To:TomasCharvat)
You can get them if you add an event listener:
window.addEventListener('click', $scope.clickEventFunktion);
In the function you can get the coordiates of the click event:
$scope.clickEventFunktion=function(){
console.log(window.event.pageX);
console.log(window.event.pageY);
mn1
(To:TomasCharvat)
Another version of the mention functionality in the replay of @mn1
document.addEventListener('click', function(event) {console.log("click() 1 called");
  $scope.lastClick = {
    x: event.pageX, y: event.pageY};
So in this case you can save the value of the click listerner to an $scope parameter and use it later outside the click event e.g. in  ion-popover-view devinition.
Thank you for advice mn1 and RolandRaytchev
both methods works fine. I chose this way:
var ClickX = 0;
var ClickY = 0;
var width = 0;
var height = 0;
$scope.clickEventFunction = function(){
ClickX = window.event.pageX;
ClickY = window.event.pageY;
width = window.innerWidth;
height = window.innerHeight;
console.info('Coordinates: x=' + ClickX + ' y=' + ClickY + ' DisplaySize: ' + width + 'x' + height);
Regards
Tomas
