Vuforia Studio
Vuforia View
Experience Service (On-premises)
All in all a good set of upgrades. Here is my feedback after an hour or so of playing around.
@tmccombie I can't edit my post to tag you for some reason. But can you find an answer to this question?
@jmikesell wrote
- Can you elaborate on what is required to take advantage of the "Improved detection and tracking of Model Targets" Are the improvements all on the View side? Will I see improved tracking on experience published prior to 8.3.5 when viewed in View 8.3.5? Or do we need to republish in 8.3.5? I have tested an 8.3.4 vs 8.3.5 publish but all my devices have auto updated to 8.3.5 so i don't have an older View client to test with.
@jmikesell There are some improvements from Studio as well. To utilize the improved detection & tracking you need to upgrade View to 8.3.5 and republish your project in Studio 8.3.5. On-prem users should also ensure they are using Vuforia Experience Service 8.3.5 for this feature.
Thanks tmccombie for that info. I had updated and republished but it didn't work nevertheless.
What helped, was updating windows, it works now.
Something else that's new for Vuforia View on the HoloLens:
There is now a Page Down and Page Up button on the experience selection page (the floating thumbnails that come up when you scan a ThingMark or go to the Library), meaning that you are no longer limited to the 6 most recently published experiences. This is a great addition.
Unfortunately, it looks like the problem with changing sequences dynamically via JS as outlined in this thread are still there.
Hello, one question regarding the Surface Pro:
I can't drop my model at spatial mapping, the app doesn't react when I tip in order to place the model.
I have a Surface Pro i/ Modell 1796
