What types of widgets can I specify position?
CHASEONHO
18-Opal
The following css style is applied to the grid widget, but the button does not position well.
.pos {
margin-top: 30%;
height: 30ch;
When fixing the position of a widget, is it common to specify a position with a grid widget and then include the widget in it?
Any other good suggestions?
regards
1 ACCEPTED SOLUTION
Yes, it is recommended to use the grid widget to help with positioning of widgets.
If so, do you specify as many as% when specifying the location?
Or do you recommend positioning in px?
I have found specifying in px works well.
Thanks @tmccombie, have a good day
