2 Creo sessions running in parallel (Connected to Windchill and local)
  • July 17, 2024
  • 862 views
Is it possible to have 2 Creo sessions running in parallel with the 1st session connected to Windchill and the 2nd one working in local?
Creo Parametric 7.0.2.0
As soon as I connect one session, the other session is connected. It's exactly the same behaviour when I disconnect one of them from Windchill.
Best answer by MartinHanak
YES it is possible.
INFO: By default Parametric\bin subdirectory contains parametric.psf file.
You can (for example):
1.] rename parametric.psf to parametric_with_WCH.psf edit
modify ... DESC=Creo Parametric (with WCH)
add line at the end of file ... ENV=PTC_WF_ROOT=C:\PTC_WF_ROOT_with_WCH
2.] copy parametric_with_WCH.psf to parametric_without_WCH.psf edit
modify ... DESC=Creo Parametric (without WCH)
add line at the end of file ... ENV=PTC_WF_ROOT=C:\PTC_WF_ROOT_without_WCH
When you start Creo using parametric.exe shortcut, dialog box appears showing two options:
YES it is possible.
