I have been having some issues with the active window not "returning" to the appropriate window when a prompt box is closed.
Here is a thread I posted earlier about Regenerating and Printing:
I have now found that sometimes when editing a text property within the properties box, when the box is closed, the window from which it came is not the active window (which I would expect). I find this out typically by typing a mapkay and not seeing the text pop up. Once I either click on the window, or tab to it, I can then run the mapkey. Anyone else seeing such behavior.
Thanks, Dale
