Adding parameters by automation in Intralink
venkatraj
I need to add Parameters for nearly a thousand parts in pro/intralink. Currently me and my team is opening each path, add these new parameters and checkin. Is there any way I can automate this or even a faster approach. Can someone point me in the correct direction.
3 REPLIES 3
Easy!  Just batch process the models in your Active Workspace using Nitro-BOM and Excel.
Here is a generic example...
https://www.youtube.com/watch?v=jAn6PoYYrN8
Dave
BenLoosli
(To:venkatraj)
Modelcheck in batch mode can do this.
@venkatraj
You may use Creo Distributed batch as well.
