Analysis - Reflection curves
DeanLong
Hi All,
I am curiousif anybody has a work around for this. I traditionally just deal with the inconvienience of creating new analyses to see the areas I am interested without saving them. Ideally, however,I would like a reflection map without the tessellation that occurs with a "saved" analysis. If it a "Quick" analysis it's okay. But I need to save the analysis for animations.
I have tried making the underlying color transparent which also makes the relfection map transparent too.
thanks.....
1 REPLY 1
I'm having the same problem. Did you ever figure the solution? My reflection curves are disconnected/covered by the part appearances.
Im using Creo 5.0
