Hi All,
I am curiousif anybody has a work around for this. I traditionally just deal with the inconvienience of creating new analyses to see the areas I am interested without saving them. Ideally, however,I would like a reflection map without the tessellation that occurs with a "saved" analysis. If it a "Quick" analysis it's okay. But I need to save the analysis for animations.
I have tried making the underlying color transparent which also makes the relfection map transparent too.
thanks.....
I'm having the same problem. Did you ever figure the solution? My reflection curves are disconnected/covered by the part appearances.
Im using Creo 5.0
