CREO 5.0 : unable to define another path in Assistant of installation PTC
fafa
8-Gravel
Hey everyone,
I tried to install creo 5.0 by changing the default path which is C:\Program Files\PTC.
I created a new map network drive called J: and shared it as admin but when I launch the Assistant of Installation PTC , it is impossible to change the default path. It indicated me BANNED for all applications such as Parametric , Simulate etc.
It seems so strange for me ...  anyone got the same issue ?
In attachment you'll see a screenchot of my issue.
Thank you in advance
TomU
(To:fafa)
Check the folder security settings.  Creo needs "Full Control".  (These are different from the share permissions.)
2 REPLIES 2
TomU
(To:fafa)
MartinHanak
(To:TomU)
I think share permissions must be also "Full Control".
Martin Hanák
