Can not find "parametric.exe"
jpennington-2
I did the student install and when I go to open PTC Creo Parametric 3.0 M070 it notes windows can not find parametric.exe. What have I done wrong?
by default parametric.exe file is located in Creo3_LOADPOINT\Creo 3.0\M070\Parametric\bin directory. Can you check this ?
MH
Martin Hanák
There are two parametric files. One is a windows batch file the other is PTC startup file
so your bin directory contains parametric.bat and parametric.psf ... unfortunatelly I do not know, what "beast" have eaten your parametric.exe. Maybe your installation is corrupted -OR- antivirus software put this file into quarantine.
MH
Martin Hanák
