Can not modify hose created in WF4
TractorGuy
I'm currently using Creo 2.0 and I need to modify a hydraulic hose that was created in WF4 using Pro/Piping. I'm about to pull my hair out because I can not modify this model at all. Here is what I have done/checked:
1. I made sure that the model is not set to read only and I have confirmed that I can make changes to the model.
2. The pipeline will display in "Thick Pipes" mode, but I can not figure out how to make it show the pipeline segments as centerlines (the green lines).
3. I have tried Modify Pipeline and it will not allow me to select anything in the model or anything on the model tree.
4. I have tried using the Find tool and did a filter by pipe features and it shows nothing.
5. I have checked my company's config.pro settings and there are no piping related options set.
Does anyone know what I am doing wrong? Its like the pipe solid is there but none of the pipeline segments will show up in the model.
See if the assembly layer tree has the piping centerlines hidden.  You will have to un-hide it to see them.
StephenW
(To:TractorGuy)
Is it that the pipe features are in an upper level assy?
TractorGuy
(To:StephenW)
The pipe features are in the hose assembly model along with two end fittings.
TractorGuy
(To:lernst-2)
Yup...on the wrong layer. It is definitely Monday.
