Can you configure Creo View Express (Product View Express)?
MikeGwin
Does anyone know how to configure creo view (product view) express? There is a pvexpress.cfg file in the load point bin directory.
Not sure how to configure start up and working directory or if there are any other options you can configure like in Creo (Pro/E).
Do I put my config.pro in the bin directory?
Thanks in advance...Mike
BrianMartin
(To:MikeGwin)
Hi Mike...
Down inside your <loadpoint> which is usually something like C:\Program Files\PTC\ProductView Express\preferences\ProductView you should see two XML files and a readme file.
You can edit the preferences for Creo View Express using the XML file. The readme file explains all about it. You can also interactively tweak the configuration settings from the File>Options menu within the application directly.
To change the starting directory, edit the shortcut that launched Creo View Express. Change the Start In location. This will do the trick. Putting your config.pro in the \bin directory will have no effect. That file is only used for Creo Parametric or Creo Elements/Pro (Pro/ENGINEER).
If that's still unclear, just write back and I'll go into more detail.
Thanks!
-Brian
BrianMartin
(To:MikeGwin)
Hi Mike...
Thanks!
-Brian
