i want to ask if is it possible to change color of UI in Creo 1.0 (no viewport) cause white color is insane for my eyes?:D
thank you for any answer
Vladimir
Guys we cant change color of UI. It was confirmed by PTC. Maybe in next releases as ussual:D
Vladimir
Main work area changed with
File>Options>System Colors>Graphics>Background
Other colors are affected by Themes in Win7
Burt,
please, can you tell me how to change default background color (White) of Creo Parametric 1.0 Tabs, Ribbons, Menus using Windows 7 Theme ? I tried it with no success...
Martin Hanak
Yes, it is big problem for me too. White color is very tired, I have not working with Creo in happy. Wildfire with blue color was best. On WinXP I have not no chance changed color of UI (dialog panels, ribbons, menu). I hope that PTC will have some improved with this.
I use a grey gradient background 177:177:177 236:236:236
also changed selected to yellow ( 255:255:0 )
with the new transparent text, dimensions now seem to get lost in the model
Vladimir
If you like your Wildfire color, Just open your Wildfire, then export the syscol.scl file, then open Creo, go to File>Option>System Color> Color Scheme>Custom then browse for syscol.scl file you just exported from Wildfire.
Hope this Help.
either they think we need more lighting in our cubes since most of us probably like our environment dim
or
they know we like a dim environment and are trolling us
