Component Operations
justgeo
Hey everyone,
I'm trying to use the MERGE and CUT OUT functions under Component Operations. However they are greyed out. Is there a config setting that needs to be set or some specific order of selecting parts in the assembly?
Thanks for the help.
Justin Giaquinto
Covidien
Boulder CO
8 REPLIES 8
Justin,
I think you need the Advanced Assembly license to do these operations. Do you have this license pack?
James
mlocascio
(To:justgeo)
Did we already address this?
We use Merge and Cutout daily and we do not have "Advanced Assembly Extension".
This is a core funtion and should be available to you. When you select "Component Operations", you should see the old Pre-Wildfire Menu Manager with both options listed among others. I have never seen these greyed out.
Do you have a screen capture?
ΜΟΛΩΝ ΛΑΒΕ
They won't work in a simplified rep.
I don't think a simplified rep will grey the commands out. Check and make sure there are no failed models in the assembly
and that you have a 'green' light on the bottom......... Still thinking!
We have had Pro/E thru WF4 without the AAX and have always had this
functionality. I'm not sure if that changed or not with Creo.
Tony
justgeo
(To:justgeo)
There are no Simp Reps in the assembly, no failed components, and everything had been regenerated.
Here's a screen shot of it greyed out.
justgeo
(To:justgeo)
Actually I'm trying to cut out this clip shape frrom the bottom of the frame. So yea, there is interferance between the two parts. Smiley Happy
Sent: Sunday, January 26, 2014 4:22 PM
To: Giaquinto, Justin
Subject: RE: [proecad] - RE: Component Operations
Justin,
Just throwing this out and it may have already been suggested – Have you tried resizing your pins so that there is a definite interference between the components to see if this “un-greys” the commands?
Just a thought.
Scott Schultz
Principal Consultant
3D Relief Inc.
3700 Willow Creek Drive
Raleigh, NC 27604
