Contrast of part edges
JozefBucha
2-Explorer
Is there any way to make edges of part more contrast with rest of part (something like in Catia or Solid Edge), I have just found in View/Display Settings/Model Display/Shade with Edges.
Thanks for answer
Jozef,
if you use ProE, then you have bad luck ...
In Creo Parametric, you can use File > Options > System Colors > Shaded Edge
Martin Hanak
Martin Hanák
Jozef,
Martin Hanak
Martin Hanák
Thanks for answer. I am using Wildfire 5, but we have also Creo, so I will check it there.
Jozef
