Hi
Is there a way of adding the green/tickbox for saving frequently, onto the mini tool bar. Save the hassle of diving across screen all the time.
Charlie
Might those links are helpful
In addition to Horst's comments, I'm wondering if you're talking about the Green Checkmark (i.e. "OK"). If so, for many/most (all?) operations, you can click the middle mouse button as a shortcut. Then you don't even need to customize your mini tool bar!
I hope this helps!
andy
