Refer image blue color marked areas sometime to as image shown. sometime its not in that area refer 2nd image.
i dont need this empty preview area. so need config option or control option. pls tell anyone
Hello
It seems that your are looking for the option file_open_preview_default, to have no preview window set it to collapsed (wich is the default value of the option)
Hello
